Today I skipped ahead a little in the construction sequence by installing and match drilling the gear leg mounts to the F-770 forward side skins and longerons. I also match drilled the fuel tank forward inboard mount brackets to the F-770 forward side skins and associated stiffener angles. With this complete I can debur the new or enlargened holes in the F-770 forward side skins and associated components so I do not need to be drilling holes after the various components have been cleaned, abraded, alodined and primed.
